[GRASS-dev] [GRASS GIS] #1083: Wingrass7 - versioned libgrass
needed for start, unversioned libgrass needed for wxnviz
trac at osgeo.org
Sat Jun 5 19:12:31 EDT 2010
#1083: Wingrass7 - versioned libgrass needed for start, unversioned libgrass
needed for wxnviz
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Keywords: wingrass, wxnviz, libgrass | Platform: MSWindows Vista
Cpu: x86-32 |
from the dev-ml
(http://lists.osgeo.org/pipermail/grass-dev/2010-June/050750.html)
>-----Ursprüngliche Nachricht-----
>Von: Martin Landa
>Gesendet: 05.06.2010 23:58:48
>An: Hamish
>Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as
nviz_tools: ImportError
>Hi,
>2010/6/5 Hamish
>> I haven't been paying too much attention, but it would seem to me that
if
>> you are moving libraries out of the private $GISBASE tree and into the
>> public osgeo4w lib dir, removing the versioning from the files is the
last
>> thing you'd want to do.
>Helmut is trying to do the opposite thing. He is moving grass libs
>from public osgeo4w lib dir into the private $GISBASE tree. It's quite
>reasonable approach for WinGRASS installer.
I will revert r42490, because WinGrass7 (from the WinGrass-installer)
seems to need versioned libgrass_*.7.0.svn.dll in C:\Program Files\GRASS-
70-SVN\extralib for
starting and unversioned libgrass_*.dll C:\Program Files\GRASS-70-SVN\lib
for
wxnviz. with r42490 WinGrass7 isn't starting, with reverted r42490
WinGrass7 is
starting but wxnviz (3D view mode) isn't working.
I will open a ticket because a duplication of files should be avoided.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1083>
