[GRASS-dev] r.sun and pj_do_proj() calls
Seth Price
seth at pricepages.org
Wed Jun 9 02:41:29 EDT 2010
I'm working on translating r.sun to OpenCL to run on the GPU, but I've
hit a bit of a snag. I'm hoping y'all can help or at least tell me
what I'm looking at.
The root of it is that I can't call pj_do_proj() from within the
OpenCL kernel, so I need to pass that in from the outside. For
example, on line 1824 of main.c in the current SVN has us calculating
the lat/long if we aren't passed in files latin and longin. So for the
OpenCL version I'll need to make latin and longin arrays ahead of time
instead of calculating it in the loop.
The problem is in rsunlib.c at line 250. How can I avoid this
pj_do_proj() call? I was thinking that because I have the lat/long
coordinates for all points, I can use that on lines 255 & 256,
effectively changing G_projection() to return PROJECTION_LL and
avoiding going into the 'if' statement. I don't know if that will
work, though. I really don't know what's going on here enough to feel
comfortable changing the calculation.
Suggestions? Code?
~Seth
