[GRASS-dev] WinGrass7-installer + "GRASS 7.0.SVN with MSYS"-desktop-shortcut
Helmut Kudrnovsky hellik at web.de
Mon Jun 14 13:59:58 EDT 2010
hi,
-----Ursprüngliche Nachricht-----
Von: Glynn Clements
Gesendet: 14.06.2010 18:01:27
An: Helmut Kudrnovsky
Betreff: Re: [GRASS-dev] WinGrass7-installer + "GRASS 7.0.SVN with MSYS"-desktop-shortcut
Helmut Kudrnovsky wrote:
> >the desktop-shortcut to start WinGrass7 with Msys is actuallay following:
> >"C:\Program Files\GRASS-70-SVN\msys\msys.bat" "/grass/bin/grass70 -wxpython"
> >(http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-Installer.nsi#L624)
> >I've tried a little different approaches to launch WinGrass7 with a msys-command-line , but no success at
> >the moment.
>> maybe any hints?
>Create a batch file which sets SHELL to the full Windows path to MSys'
>sh.exe then runs grass70.py
now I'm a little bit confused, because the installed C:\Program Files\GRASS-70-SVN\grass70.bat already
does this:
rem Path to the shell command
set GRASS_SH=%GISBASE%\msys\bin\sh.exe
%GRASS_PYTHON% "%GISBASE%\grass70.py" %*
in my original post (http://lists.osgeo.org/pipermail/grass-dev/2010-April/049998.html):
"in this windows-console you can start - if you want within a Grass7-session - python or a shell
(in this shell you have access to sed, awk, ...) and can use also all windows-commandline-tools."
so therefore I've suggested to remove the "WinGrass7 with msys-shortcut" because there is already a shell accessible.
best regards
Helmut
___________________________________________________________
WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
