[GRASS-dev] access to grass (trunk 7.0.svn ) vector map from python
Fernando Pacheco fernando.pacheco at ingesur.com.uy
Tue Jun 15 11:02:10 EDT 2010
I'm trying to access a grass vector map with python (2.6). I'm using the svn
version (revision 42 565) but keep getting "Segmentation fault" when trying
to open the file with Vect_open_old (map, input, mpaset). The code I'm using
can be found here: http://osgeo.pastebin.com/VLGunxyq
Can you please tell me I'm doing wrong (the same code works well with python
libraries generated with SWIG)?. Greetings. Thank you very much.
Ing. Fernando Pacheco M.S.L.
Ingesur srl
Dirección: Requena 1062 ap.302, Montevideo, Uruguay.
Teléfonos: (+598 2) 408 90 48, (+598 9) 962 79 32
Web: http://ingesur.com.uy/
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100615/0b42cfad/attachment.html
