[GRASS-dev] [GRASS GIS] #974: [Patch] add option to d.vect to make symbol size proportionate to square root of size_column
GRASS GIS trac at osgeo.org
Mon Mar 1 08:13:11 EST 2010
root of size_column
 Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Display      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 The attached patch adds a flag to d.vect to use the square root of the
 size_column values. This allows to make the surface of circles instead of
 their heights proportionate to the size value.
 I did not want to commit immediately as I saw that Hamish was working on
 d.vect. BTW thanks for allowing to scale the size_column value.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/974>
