[GRASS-dev] Re: [GRASS GIS] #974: [Patch] add option to d.vect to
make symbol size proportionate to square root of size_column
trac at osgeo.org
Tue Mar 2 04:21:35 EST 2010
#974: [Patch] add option to d.vect to make symbol size proportionate to square
root of size_column
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by hamish):
(trac is logging me out every 5 minutes and it's driving me nuts!)
I'm fine with the patch, a couple of comments though,
- patches are '''''much''''' easier to review if they are kept to just
the change you are talking about. ie gratuitous whitespace changes should
be put in another patch if at all. signal:noise ratios & wasted time ...
- please don't run the indent script unless you've added a bunch of new
code which needs it. see the comments in the SUBMITTING file.
- if using sqrt() please #include <math.h>
- sqrt_flag->description: please split into two parts: short description
on flag->label= line and "i.e." on flag->description= line (it becomes the
tooltip).
non-specific comments-
- I worry that the d.vect interface is becoming like a 747 cockpit for
new users. So many controls it becomes overwhelming. the solution I guess
is good use of tabs and specific task wrapper scripts (eg addons
d.stations and d.varea).
- now that d.vect has support for sizecol, rgbcol, widthcol, zcolor, etc,
what is left for d.thematic.linepoint to do?
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/974#comment:1>
