[GRASS-dev] Re: [GRASS GIS] #979: WxGUI fails to display vector
attribute table
trac at osgeo.org
Tue Mar 2 03:03:51 EST 2010
#979: WxGUI fails to display vector attribute table
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, database
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hamish):
* keywords: wxgui, windows, database => wxgui, wingrass, database
Comment:
it is unclear to me how you are triggering the bug. Vector -> Reports and
stats -> Basic vector metadata ?? (which works for me)
* query in map display window works
* right click on map name in layer manager and start attribute table
manager works
I'd be more suspicious that this is due to db.select being used instead of
v.db.select.
(db.select only works on maps in the current mapset, while v.db.select
accepts @othermapset. see v.db.* scripts for workaround)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/979#comment:2>
