[GRASS-dev] Re: [GRASS GIS] #979: WxGUI fails to display vector attribute table
GRASS GIS trac at osgeo.org
Tue Mar 2 05:44:11 EST 2010
  Reporter:  marisn           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  blocker          |   Milestone:  6.4.0
 Component:  wxGUI            |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wxgui, wingrass, database
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by marisn):
 Replying to [comment:2 hamish]:
 > it is unclear to me how you are triggering the bug.
 As I'm using WxGUI for first time, I was not aware of so many options.
 Start GRASS, Location=Spearfish6 Mapset=user
 >Vector -> Reports and stats -> Basic vector metadata ?? (which works for
 me)
 It's v.info and not WxGUI. Still it reports wrong database, but prints out
 correct column names.
 >  * query in map display window works
 It's v.what and not WxGUI. Works fine, as it doesn't fiddle with db
 settings.
 >  * right click on map name in layer manager and start attribute table
 manager works
 This is WxGUI specific. '''Fails''' in same way as pressing button "Show
 attribute table"
 You are right about this. Attribute data works fine, if I launch wxgui
 within PERMANENT mapset.
 > I'd be more suspicious that this is due to db.select being used instead
 of v.db.select.
 > (db.select only works on maps in the current mapset, while v.db.select
 accepts @othermapset. see v.db.* scripts for workaround)
 > Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/979#comment:3>
