Hi all!
I try to compile grass7 from svn I reach this error:
GRASS GIS compilation log
Started compilation: Wed Mar 3 12:34:18 CET 2010
Errors in:
/home/pietro/builds/grass70/src/grass70/lib/python
/home/pietro/builds/grass70/src/grass70/scripts/d.vect.thematic
/home/pietro/builds/grass70/src/grass70/scripts/r.in.srtm
/home/pietro/builds/grass70/src/grass70/scripts/v.db.update
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
then I try to run 'make':
$ cd src/grass70/lib/python/
python $ make
python -m py_compile /home/pietro/builds/grass70/src/grass70/dist.x86_64-
unknown-linux-gnu/etc/python/grass/script/core.py
Sorry: IndentationError: ('expected an indented block',
('/home/pietro/builds/grass70/src/grass70/dist.x86_64-unknown-linux-
gnu/etc/python/grass/script/core.py', 71, 10, ' return val\n'))make: ***
[/home/pietro/builds/grass70/src/grass70/dist.x86_64-unknown-linux-
gnu/etc/python/grass/script/core.pyc] Error 1
Pietro
