[GRASS-dev] svn: 41275 (Identation error in core.py?)
Markus Neteler neteler at osgeo.org
Wed Mar 3 15:05:31 EST 2010
On Wed, Mar 3, 2010 at 12:58 PM, Pietro Zambelli <peter.zamb at gmail.com> wrote:
> Hi all!
> I try to compile grass7 from svn I reach this error:
> GRASS GIS compilation log
> Started compilation: Wed Mar  3 12:34:18 CET 2010
> Errors in:
> /home/pietro/builds/grass70/src/grass70/lib/python
> /home/pietro/builds/grass70/src/grass70/scripts/d.vect.thematic
> /home/pietro/builds/grass70/src/grass70/scripts/r.in.srtm
> /home/pietro/builds/grass70/src/grass70/scripts/v.db.update
> In case of errors please change into the directory with error and run 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> then I try to run 'make':
> $ cd src/grass70/lib/python/
> python $ make
> python -m py_compile /home/pietro/builds/grass70/src/grass70/dist.x86_64-
> unknown-linux-gnu/etc/python/grass/script/core.py
> Sorry: IndentationError: ('expected an indented block',
> ('/home/pietro/builds/grass70/src/grass70/dist.x86_64-unknown-linux-
> gnu/etc/python/grass/script/core.py', 71, 10, '    return val\n'))make: ***
> [/home/pietro/builds/grass70/src/grass70/dist.x86_64-unknown-linux-
> gnu/etc/python/grass/script/core.pyc] Error 1
I have tried with today's SVN - no such problem.
[neteler at north python]$ touch core.py
[neteler at north python]$ make
/usr/bin/install -c  -m 644 core.py
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/core.py
Perhaps you have local modifications? Which python version do you use?
Markus
