[GRASS-dev] Re: [GRASS GIS] #908: No Font Definition File,
windows xp
trac at osgeo.org
Fri Mar 5 14:44:24 EST 2010
#908: No Font Definition File, windows xp
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Installation | Version: svn-releasebranch64
Resolution: | Keywords: v.label.sa, g.mkfontcap, wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:15 hellik]:
> the only thing at the moment is, g.mkfontcap works longer (searching for
fonts) than the WinGrass-installer installs WinGrass, so after closing the
WinGrass-installer the Windows-command-box is still opened.
> maybe is there a possibility to run the ''run_gmkfontcap.cmd''-script in
the background without opening Windows-command-box?
It depends upon what's opening the console Window. If it's NSIS, there
might be an option within NSIS to do it. Otherwise, "`start /b ...`" might
work.
> p.s. how can I delete an old attachment in track?
I don't think that you can, although you can replace an attachment with an
updated version.
Ticket URL: <http://trac.osgeo.org/grass/ticket/908#comment:16>
