[GRASS-dev] Re: [GRASS GIS] #908: No Font Definition File,
windows xp
trac at osgeo.org
Fri Mar 5 15:04:44 EST 2010
#908: No Font Definition File, windows xp
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Installation | Version: svn-releasebranch64
Resolution: | Keywords: v.label.sa, g.mkfontcap, wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:16 glynn]:
> Replying to [comment:15 hellik]:
> > the only thing at the moment is, g.mkfontcap works longer (searching
for fonts) than the WinGrass-installer installs WinGrass, so after closing
the WinGrass-installer the Windows-command-box is still opened.
> > maybe is there a possibility to run the ''run_gmkfontcap.cmd''-script
in the background without opening Windows-command-box?
> It depends upon what's opening the console Window. If it's NSIS, there
might be an option within NSIS to do it. Otherwise, "`start /b ...`" might
work.
there would be an option with a second bat starting run_gmkfontcap.bat
minimized:
@echo off
rem
rem #run run_gmkfontcap.bat minimized
rem
start /MIN "C:\Program Files\GRASS-65-SVN\etc\run_gmkfontcap.bat"
exit
I've tried this by invoking the above script by the installer, a minimized
console is started, but ''run_gmkfontcap.bat'' isn't running/started.
''run_gmkfontcap.bat'' itself invoked by the installer is working.
I couldn't find anything on NSIS-side.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/908#comment:17>
