[GRASS-dev] Re: [GRASS GIS] #979: WxGUI fails to display vector attribute table if default db connection is missing
GRASS GIS trac at osgeo.org
Tue Mar 9 09:21:34 EST 2010
missing
  Reporter:  marisn           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  wxGUI            |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wxgui, wingrass, database
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by marisn):
  * summary:  WxGUI fails to display vector attribute table => WxGUI fails
Comment:
 Hamish, You are right about db.connect issue. I just started to look into
 code and also decided to test db.connect output:
 (Tue Mar 09 16:06:12 2010)
 db.connect -p
 driver:
 database:
 schema:
 group:
 (Tue Mar 09 16:06:12 2010) Command finished (0 sec)
 First step to reproduce issue is "Create new mapset in wxgui startup
 screen".
 When I created new mapset in wxgui startup screen, it's directroy had only
 "WIND" file and ".tmp" folder. No "VAR" files. Missing "VAR" file in new
 mapsets is discussed in #7
 Still wxgui should NOT fail if default DB connection is missing (or is
 incorrect etc.), as only selected vector map connection matters.
 When I copy vector map from PERMANENT to newMapset with g.copy, there is
 message, that ~"Default db connection is created" and also afterwards
 there is an "VAR" file in mapset. Then displaying attribute data for
 current mapset or PERMANENT works just fine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/979#comment:9>
