[GRASS-dev] Re: [GRASS GIS] #979: WxGUI fails to display vector attribute table if default db connection is missing
GRASS GIS trac at osgeo.org
Fri Mar 12 09:23:30 EST 2010
missing
  Reporter:  marisn           |       Owner:  martinl
      Type:  defect           |      Status:  assigned
  Priority:  critical         |   Milestone:  6.4.0
 Component:  wxGUI            |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wingrass, database
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by martinl):
 * cc: grass-dev at lists.osgeo.org (added)
  * keywords:  wxgui, wingrass, database => wingrass, database
  * status:  new => assigned
  * owner:  grass-dev at lists.osgeo.org => martinl
Comment:
 Replying to [comment:9 marisn]:
 > Still wxgui should NOT fail if default DB connection is missing (or is
 incorrect etc.), as only selected vector map connection matters.
 Hopefully fixed in r41403. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/979#comment:10>
