[GRASS-dev] Location wizard (missed window to select +towgs params)
Massimo Di Stefano massimodisasha at gmail.com
Fri Mar 12 04:46:36 EST 2010
Hi All,
i did svn up on the grass65 src code,
now tring to create a location
"  Gauss Boaga Rome 40 fuse E "
using :
 "location wizard -> select epsg code -> search for : 3004"
in the paste release (build less than 1 month ago) after select the epsg:code(3004)
grass prompt me to the window :
http://img534.imageshack.us/img534/8254/schermata20100312a09564.png
to select the +towgs parameters
with the latest svn version this window doesn't appair and  the locaqtion is created using the defaults parameters :
http://img705.imageshack.us/img705/6675/schermata20100312a10350.png
i can see there are recent code changes about the location wizard, maybe something is missed?
thanks for any comment.
Regards,
Massimo.
