[GRASS-dev] Location wizard (missed window to select +towgs params)
Martin Landa landa.martin at gmail.com
Fri Mar 12 14:38:03 EST 2010
2010/3/12 Massimo Di Stefano <massimodisasha at gmail.com>:
>  "location wizard -> select epsg code -> search for : 3004"
> in the paste release (build less than 1 month ago) after select the epsg:code(3004)
> grass prompt me to the window :
> http://img534.imageshack.us/img534/8254/schermata20100312a09564.png
> to select the +towgs parameters
> with the latest svn version this window doesn't appair and  the locaqtion is created using the defaults parameters :
> http://img705.imageshack.us/img705/6675/schermata20100312a10350.png
it seems to be bug in g.proj -
g.proj epsg=3004 datum=-1
no output is printed...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
