[GRASS-dev] Re: [GRASS GIS] #509: wxgui: startup menu crunched on
small display
trac at osgeo.org
Fri Mar 12 09:52:04 EST 2010
#509: wxgui: startup menu crunched on small display
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: startup
Platform: All | Cpu: x86-32
Comment (by martinl):
Replying to [comment:7 hamish]:
> bug still there. more screenshots added.
> xfce panels in screenshots are 24px tall each, so on the display the
window is created at 552px tall. is there a way for wx to know the desktop
size? if so and it is less than 600px tall (tested minimum) switch off the
graphic and the "world leading" text? or maybe switch off both the
"welcome to+world leading" lines and leave the graphic there?
does the attached patch helps? Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/509#comment:9>
