[GRASS-dev] Re: [GRASS GIS] #509: wxgui: startup menu crunched on small display
GRASS GIS trac at osgeo.org
Fri Mar 12 11:17:49 EST 2010
  Reporter:  hamish  |       Owner:  martinl
      Type:  defect  |      Status:  assigned
  Priority:  minor   |   Milestone:  6.4.0
 Component:  wxGUI   |     Version:  6.4.0 RCs
Resolution:          |    Keywords:  startup
  Platform:  All     |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:9 martinl]:
 > does the attached patch helps? Martin
 partially. now the buttons don't fall behind, but the window ends at the
 bottom horiz scrollbars of the mapset/loc boxes, and you somehow have to
 know to make the box bigger to magically find the missing buttons.
 on WinGrass where the buttons end up on top this would be a regression as
 it is ugly, but at least you can see & use them.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/509#comment:10>
