[GRASS-dev] [GRASS GIS] #1009: r.param.scale outputs wrong values
in last (bottom) row
trac at osgeo.org
Sun Mar 14 16:33:32 EDT 2010
#1009: r.param.scale outputs wrong values in last (bottom) row
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
Cpu: Unspecified |
When feature map is created, it contains also data in last (most bottom
one) row, still it's impossible to gather data for that row, as
r.param.scale uses sliding window method and thus last line would have to
deal with NULLs coming from outside from computational region. Current
r.param.scale output more looks like last line is repeated twice instead
of setting it to be NULL.
Test procedure:
g.region rast=elevation.dem at PERMANENT
r.param.scale input=elevation.dem at PERMANENT output=features param=feature
Ticket URL: <http://trac.osgeo.org/grass/ticket/1009>
