[GRASS-dev] [GRASS GIS] #1010: WxGUI d.vect/rast modules stuck in running state with d.mon
GRASS GIS trac at osgeo.org
Sun Mar 14 16:54:46 EDT 2010
 Reporter:  marisn        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  6.4.0
Component:  wxGUI         |     Version:  svn-releasebranch64
 Keywords:  wxgui, d.mon  |    Platform:  Linux
      Cpu:  x86-64        |
 Start monitor (d.mon x0); Launch d.rast module (with new wx based UI).
 Choose raster to display. Press "RUN". No output in "command output" tab
 and module doesn't stop running (only "STOP" button is active). Still
 module has done it's job - there is content in monitor. Only way how to
 close this window is by window close button, as "STOP" button emits only
 errors:
 GRASS 6.4.0svn (personal_spearfish_60):~/soft/grass_64 > d.mon x0
 using default visual which is TrueColor
 ncolors: 16777216
 Graphics driver [x0] started
 GRASS 6.4.0svn (personal_spearfish_60):~/soft/grass_64 > d.vect
   File "/home/maris/soft/grass_64/dist.x86_64-unknown-linux-
 gnu/etc/wxpython/gui_modules/goutput.py", line 486, in OnCmdAbort
     self.cmdThread.abort()
 gnu/etc/wxpython/gui_modules/goutput.py", line 108, in abort
     self.requestCmd.abort()
 AttributeError: 'CmdThread' object has no attribute 'requestCmd'
Ticket URL: <http://trac.osgeo.org/grass/ticket/1010>
