[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
trac at osgeo.org
Mon Mar 15 15:59:06 EDT 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hellik):
Replying to [comment:3 glynn]:
> Replying to [comment:2 hellik]:
> > so Grass7-compiling on Win-OS 32-bit and testing won't be possible (at
the moment)?
> Remind me again: what is being broken by the LFS mis-detection?
> I occasionally compile and test 7.0 on Win32 (Windows XP), and haven't
noticed any problems, but I haven't tested it thoroughly.
> The one thing which I remember is that "make test" in lib/vector/diglib
fails (it compares the output against test64.ok and fails because of the
32-bit off_t).
> You could just modify Platform.make by hand after running configure.
in Platform.make there is after running configure
#Large File Support (LFS)
USE_LARGEFILES = 1
should this be?
USE_LARGEFILES =
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:5>
