[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
trac at osgeo.org
Mon Mar 15 17:54:17 EDT 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hellik):
Replying to [comment:4 hellik]:
> Replying to [comment:3 glynn]:
> > Replying to [comment:2 hellik]:
> > > so Grass7-compiling on Win-OS 32-bit and testing won't be possible
(at the moment)?
> > Remind me again: what is being broken by the LFS mis-detection?
> see https://trac.osgeo.org/grass/ticket/930
> i get errors in /vector/diglib, /raster/r.li/r.li.patchdensity,
r.li.patchnum, /raster/r.patch, /gem.
> and I don't get any usable Grass7 (following the instructions in
http://trac.osgeo.org/grass/wiki/CompileOnWindows#Grass-7.0.svntrunk),
that means nothing is installed in C:\OSGeo4W\apps\grass.
> Helmut
so I did a completely fresh svn-checkout of g7.
there are still compiling errors.
Errors in:
/c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
/c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchdensity
/c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchnum
/c/osgeo4w/usr/src/grass_trunk/raster/r.patch
/c/osgeo4w/usr/src/grass_trunk/vector/v.patch
/c/osgeo4w/usr/src/grass_trunk/gem
- in diglib, that's
Glynn:
The one thing which I remember is that "make test" in lib/vector/diglib
fails (it compares the output against test64.ok and fails because of the
32-bit off_t).
in v.patch, r.patch r.li.patchdensity,r.li.patchnum, that seems again to
be the problem with UAC and reserverd words for safety in the windows
world. :o(
r.patch.exe: Bad file number
that's interesting, because all manifests for all exe-files are built. so
there seems to be problems with exe-files (partly) labelled with reserverd
words and executed outside a system-folder like C:\Program Files during
compilation.
but I've got a little bit further.
now both folders C:\OSGeo4W\usr\src\grass_trunk\bin.i686-pc-mingw32 and
C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32 are build and grass7
is working from in there.
but nothing is in installed in C:\OSGeo4W\apps\grass.
so this report should only be valid for lib/vector/diglib, all other
problems should be continued in https://trac.osgeo.org/grass/ticket/930.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:6>
