[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
trac at osgeo.org
Tue Mar 16 02:10:59 EDT 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows Vista | Cpu: x86-32
Comment (by glynn):
Replying to [comment:6 hellik]:
> in v.patch, r.patch r.li.patchdensity,r.li.patchnum, that seems again to
be the problem with UAC and reserverd words for safety in the windows
world. :o(
That would be my guess.
> that's interesting, because all manifests for all exe-files are built.
Ah, but they're all built in one operation at the very end of the build
process. They need to be built before "<cmd> --html-description" is run to
generate the HTML documentation.
> but I've got a little bit further.
> now both folders C:\OSGeo4W\usr\src\grass_trunk\bin.i686-pc-mingw32 and
C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32 are build and grass7
is working from in there.
> but nothing is in installed in C:\OSGeo4W\apps\grass.
I've never tested the OSGeo4W packaging. I normally just test building to
dist.<arch>, and recently "make install" (to put it into "C:\Program
Files").
> so this report should only be valid for lib/vector/diglib,
The diglib issue should only happen if you don't unset USE_LARGEFILES, and
should be harmless (the test is the last step, so failure doesn't cause
anything important to be skipped). As MinGW doesn't understand
_FILE_OFFSET_BITS, the value of USE_LARGEFILES should have no effect,
other than selecting test64.ok rather than test32.ok. IOW, it's the test
which is broken; the library itself works fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:8>
