[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
GRASS GIS trac at osgeo.org
Tue Mar 16 11:16:48 EDT 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  7.0.0
 Component:  Compiling        |     Version:  svn-trunk
Resolution:                   |    Keywords:  wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:8 glynn]:
 > > in v.patch, r.patch r.li.patchdensity,r.li.patchnum, that seems again
 to be the problem with UAC and reserverd words for safety in the windows
 world. :o(
 > That would be my guess.
 > > that's interesting, because all manifests for all exe-files are built.
 > Ah, but they're all built in one operation at the very end of the build
 process. They need to be built before "<cmd> --html-description" is run to
 generate the HTML documentation.
 I've changed 7.0 (r41457 and r41458) to build manifests at the same time
 as the executable and (by default) to embed them into the executable.
 However, I only have XP, so I can't test this; please test 7.0 on Vista or
 Win7. It should be possible to build external manifests instead with "make
 MANIFEST=external".
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:9>
