[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Wed Mar 17 09:05:35 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hamish):
what does "r.terraflow --help" say ?
(specifically the STREAM_DIR section)
/* temporary STREAM path */
struct Option *streamdir;
streamdir = G_define_option() ;
streamdir->key = "STREAM_DIR";
streamdir->type = TYPE_STRING;
streamdir->required = NO;
#ifdef __MINGW32__
streamdir->answer =
G_convert_dirseps_from_host(G_store(getenv("TEMP")));
#else
streamdir->answer = G_store("/var/tmp/");
#endif
streamdir->description=
_("Directory to hold temporary files (they can be large)");
Maris:
> Aaah - just noticed - could this be related to #520?
probably not as that should be already fixed. (just not ideal)
can you try on a small (file size) raster like elevation.dem @ Spearfish?
(existing 300mb doesn't seem so bad though)
can you try with --verbose so percent done is shown for nrows and we get
more details?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:3>
