[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Wed Mar 17 15:33:15 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hellik):
Replying to [comment:3 hamish]:
> what does "r.terraflow --help" say ?
GRASS 6.4> r.terraflow --help
Beschreibung:
Flow computation for massive grids (Float version).
Schlüsselwörter:
Raster
Benutzung:
r.terraflow [-sq] elevation=name filled=name direction=name
swatershed=name accumulation=name tci=name [d8cut=value]
[memory=value] [STREAM_DIR=string] [stats=string] [--overwrite]
[--verbose] [--quiet]
Flags:
-s SFD (D8) flow (default is MFD)
-q schweigsam
--o Ausgabedateien dürfen bereits existierende Dateien überschreiben.
--v Detaillierter Ausgabemodus
--q Schweigsame Modulausgabe
Parameter:
elevation Name der Höhenkarte.
filled Output filled (flooded) elevation raster map
direction Output flow direction raster map
swatershed Output sink-watershed raster map
accumulation Output flow accumulation raster map
tci Output topographic convergence index (tci) raster map
d8cut If flow accumulation is larger than this value it is
routed using SFD (D8) direction
(meaningfull only for MFD flow)
Standard: infinity
memory Maximum runtime memory size (in MB)
Standard: 300
STREAM_DIR Directory to hold temporary files (they can be large)
Standard: C:/Users/syringia/AppData/Local/Temp
stats Name of file containing runtime statistics
Standard: stats.out
> (specifically the STREAM_DIR section)
> /* temporary STREAM path */
> struct Option *streamdir;
> streamdir = G_define_option() ;
> streamdir->key = "STREAM_DIR";
> streamdir->type = TYPE_STRING;
> streamdir->required = NO;
> #ifdef __MINGW32__
> streamdir->answer =
G_convert_dirseps_from_host(G_store(getenv("TEMP")));
> #else
> streamdir->answer = G_store("/var/tmp/");
> #endif
> streamdir->description=
> _("Directory to hold temporary files (they can be large)");
> Maris:
> > Aaah - just noticed - could this be related to #520?
> probably not as that should be already fixed. (just not ideal)
> can you try on a small (file size) raster like elevation.dem @
Spearfish? (existing 300mb doesn't seem so bad though)
nc-data set:
g.region -p -a rast=el_D782_6m at PERMANENT
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 222504.44509601
south: 219456.439
west: 633985.268
east: 637033.27409601
nsres: 6.09601219
ewres: 6.09601219
rows: 500
cols: 500
cells: 250000
> can you try with --verbose so percent done is shown for nrows and we get
more details?
> Hamish
g.gisenv set=DEBUG=3
r.terraflow --verbose elevation=el_D782_6m at PERMANENT filled=floodeda
direction=dirr swatershed=swat accumulation=accr tci=topgr
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 222504.44509601
D3/3: region item: south: 219456.439
D3/3: region item: east: 637033.27409601
D3/3: region item: west: 633985.268
D3/3: region item: cols: 500
D3/3: region item: rows: 500
D3/3: region item: e-w resol: 6.09601219
D3/3: region item: n-s resol: 6.09601219
D3/3: region item: top: 1
D3/3: region item: bottom: 0
D3/3: region item: cols3: 500
D3/3: region item: rows3: 500
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 6.09601219
D3/3: region item: n-s resol3: 6.09601219
D3/3: region item: t-b resol: 1
D3/3: region item: format: -1
D3/3: region item: compressed: 1
cell el_D782_6m header compatible with region header
Elevation stored as FLOAT (4B)
Region size is 500 x 500
STREAM temporary files in
C:/Users/syringia/AppData/Local/Temp (THESE INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION
OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES
MANUALLY!)
file stats.out exists - renaming.
reading data from el_D782_6m to stream
C:/Users/syringia/AppData/Local/Temp/STREAM_a05332: D2/3:
G__read_Cell_head
D3/3: create window mapping (500 columns)
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
Assertion failed: nrows * ncols == str->stream_len(), file
grass2str.h, line 144
This application has requested the Runtime to terminate it
in an unusual way.
Please contact the application's support team for more
information.
the only maybe usefull information?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:4>
