[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Thu Mar 18 07:58:40 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by marisn):
Replying to [comment:5 hamish]:
> could you clean out the temp dir? in the original report you had:
> stats.out: Permission denied
> at that stage. does your user account have write permission in that dir?
This isn't Slashdot where You don't have to read original report before
replying.
(Thu Mar 18 13:55:51 2010)
r.terraflow elevation=elevation.dem at PERMANENT filled=flo1 direction=dir1
swatershed=sink1 accumulation=accu1 tci=tci1
raster elevation.dem is of type CELL_TYPE --you should use
r.terraflow.short
STREAM temporary files in C:/Users/Maris/AppData/Local/Temp
(THESE INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF
ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE
DELETE THESE FILES MANUALLY!)
(Thu Mar 18 13:55:51 2010) Command finished (0 sec)
(Thu Mar 18 13:55:58 2010)
r.terraflow --verbose elevation=elevation.dem at PERMANENT filled=flo1
direction=dir1 swatershed=sink1 accumulation=accu1 tci=tci1
cell elevation.dem header compatible with region header
Elevation stored as FLOAT (4B)
r.terraflow.short
Region size is 466 x 633
(Thu Mar 18 13:55:58 2010) Command finished (0 sec)
GRASS 6.4.0svn (Spearfish60)> cd C:/Users/Maris/AppData/Local/Temp
GRASS 6.4.0svn (Spearfish60)> pwd
/tmp
GRASS 6.4.0svn (Spearfish60)> echo "11111">stats.out
GRASS 6.4.0svn (Spearfish60)> ls
Comodo plugtmp tmp8dmank tmphq36zm.ppm tmpu1igd0.ppm
Low stats.out tmp8dmank.pgm tmpjwcn5a tmpulgzoq.ppm
Maris.bmp tmp38qqbr.ppm tmp8dmank.ppm tmpmvlbga tmpv1ri6t.ppm
STREAM_a03888 tmp6qna7p tmp_qcrpo.ppm tmpqnwipi tmpx9g0rx.ppm
WPDNSE tmp6qna7p.pgm tmpg45dva.ppm tmpqnwipi.pgm tmpyxrqeo.ppm
jusched.log tmp6qna7p.ppm tmpghekic.ppm tmpqnwipi.ppm ~nsu.tmp
GRASS 6.4.0svn (Spearfish60)> cat stats.out
"11111"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1006#comment:6>
