[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Thu Mar 25 08:19:49 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Changes (by hamish):
* priority: normal => major
Comment:
Assertion failed: nrows * ncols == str->stream_len(), file
grass2str.h, line 144
Hi, I can reproduce this in Windows XP Prof. with the 6.4.0rc6 native
wingrass installer.
The temp dir option seems to be respected.
Interestingly the stats.out file ends up in C:\Program
Files\GRASS-6.4\msys
it contains:
Free Memory=-1
[0.0] Fri Mar 26 00:57:42 2010
Command Line:
r.terraflow --verbose elevation=elevation.dem at PERMANENT
filled=terra.flooded \
direction=terra.dir swatershed=terra.sink accumulation=terra.accum \
tci=terra.tci memory=600
input elevation grid: elevation.dem
output (flooded) elevations grid: terra.flooded
output directions grid: terra.dir
output sinkwatershed grid: terra.sink
output accumulation grid: terra.accum
output tci grid: terra.tci
[0.0] MFD flow direction
[0.0] D8CUT=999999986991104.000000
[0.0] Memory size: 600.00M (629145600) bytes
region size = 288.06K (294978) elts (466 rows x 633 cols)
internal nodata value: -9999
reading raster map elevation.demto stream
C:/DOCUME~1/HAMISH/LOCALS~1/Temp/STREAM_a02052
Note the '''Free Memory=-1''' at the top of the file ...
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:7>
