[GRASS-dev] Re: [GRASS GIS] #930: Wingrass7 - compiling errors
trac at osgeo.org
Thu Mar 18 20:18:26 EDT 2010
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: wingrass, grass7
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by hellik):
Replying to [ticket:930 hellik]:
> compiling grass_trunk (grass7) on WinVista32 in the osgeo4w-stack, there
are errors in a few modules.
> a few errors with ''patch'' in the module-name, so maybe again an issue
with the UAC on WinVista? but I've this never seen in compiling grass64 or
grass65
see also https://trac.osgeo.org/grass/ticket/1008 for diglib
> Errors in:
> /c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib
> $ make
> if [ "" != "" -a -f "".html ] ; then make html ; fi
> ==============TEST=============
> make test
> make[1]: Entering directory
`/c/osgeo4w/usr/src/grass_trunk/lib/vector/diglib'
> diff OBJ.i686-pc-mingw32/test.tmp test64.ok
> Files OBJ.i686-pc-mingw32/test.tmp and test64.ok differ
> make[1]: *** [test] Error 2
> make[1]: Leaving directory
> make: *** [default] Error 2
for this:
> /c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchdensity
> /c/osgeo4w/usr/src/grass_trunk/raster/r.li/r.li.patchnum
> /c/osgeo4w/usr/src/grass_trunk/raster/r.patch
> /c/osgeo4w/usr/src/grass_trunk/vector/v.patch
r41457 MinGW: embed manifests in EXEs
these are compiling now
Ticket URL: <https://trac.osgeo.org/grass/ticket/930#comment:4>
