[GRASS-dev] r.gwflow
Massimo Di Stefano
massimodisasha at gmail.com
Fri Mar 19 17:21:30 EDT 2010
Hi Soeren,
it's my first attempt to use r.gwflow
so i have to read it's manual page
with more carefully.
i tried a fast try following the help page, but seems i did something wrong, see the logs :
http://www.geofemengineering.it/data/r_gwflow.txt
i'll try again tomorrow in the morning,
thanks !
Massimo
Il giorno 19/mar/2010, alle ore 21.27, Soeren Gebbert ha scritto:
> Hello Massimo,
> unfortunately i am not able to reproduce the segfault, because i do
> not run a 64bit system. Does this error also occurs when you start
> r.gwflow with parameters, so without gui generation?
