[GRASS-dev] r.gwflow
Fri Mar 19 17:44:15 EDT 2010
Massimo Di Stefano wrote:
> it's my first attempt to use r.gwflow
> so i have to read it's manual page
> with more carefully.
> i tried a fast try following the help page, but seems i did something wrong, see the logs :
> http://www.geofemengineering.it/data/r_gwflow.txt
Says:
> Sorry, <vx> is not a valid parameter
> Sorry, <vy> is not a valid parameter
> Sorry, <budget> is not a valid parameter
These options are only present in 7.0, not in 6.5.
