[GRASS-dev] Re: [GRASS GIS] #982: Vector modules changing db should
call Vect_set_db_updated
trac at osgeo.org
Sat Mar 20 12:06:38 EDT 2010
#982: Vector modules changing db should call Vect_set_db_updated
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
* component: default => Vector
Comment:
The original QGIS bug (http://trac.osgeo.org/qgis/ticket/1631) mentions
v.db.addcol which is a script. Hence, Vect_set_db_updated() cannot be
called. It appears that the function calls Vect_write_dblinks(Map) which
modifies the dbln file
(http://download.osgeo.org/grass/grass6_progman/field_8c_source.html#l00690).
Question: would a "touch /path/to/vector/mapname/dbln" be sufficient to
indicate the dbln file as updated?
Ticket URL: <http://trac.osgeo.org/grass/ticket/982#comment:2>
