[GRASS-dev] Re: [GRASS GIS] #982: Vector modules changing db should
call Vect_set_db_updated
trac at osgeo.org
Thu Mar 25 03:15:47 EDT 2010
#982: Vector modules changing db should call Vect_set_db_updated
Reporter: rblazek | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by rblazek):
Yes, touch would work but:
* Is it portable? I think that it is always better to avoid UNIX specific
commands even if it is already requirement.
* It is maybe better to keep functionality in one place. An option can be
added to v.db.connect, Vect_set_db_updated() called form v.db.connect and
v.db.connect called from scripts.
Ticket URL: <http://trac.osgeo.org/grass/ticket/982#comment:3>
