[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp
file on Windows when launched from wxgui
trac at osgeo.org
Thu Mar 25 20:26:54 EDT 2010
#1006: r.terraflow fails to create temp file on Windows when launched from wxgui
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hamish):
Hamish:
> in r41535 I've added a new debug message to devbr6.5 to show
> the values tested in that assert().
Replying to [comment:10 hellik]:
> now it's
> Assertion failed: nrows * ncols == str->stream_len(), file
> grass2str.h, '''line 146'''
yes, because I added two lines to the source code so now it fails two
lines later.
turn on debug messages by running `g.gisenv set="DEBUG=3"`.
(set that back to 0 to turn them off again once you are done)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:11>
