[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to create temp file on Windows when launched from wxgui
GRASS GIS trac at osgeo.org
Thu Mar 25 21:33:41 EDT 2010
  Reporter:  marisn           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  major            |   Milestone:  6.4.0
 Component:  Raster           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wxgui, wingrass, terraflow
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:9 hellik]:
 > D3/3: nrows=1350   ncols=1500    stream_len()=0
 > [[BR]]
 > '''Assertion failed: nrows * ncols == str->stream_len(), file
 > grass2str.h, line 146'''
 (assert() complains because the two sides are not the same)
 ok, so str->stream_len() is not getting set correctly.
 I wonder if this works:
   /* create output stream */
   AMI_STREAM<T>* str = new AMI_STREAM<T>();
 stream_len() is defined in include/iostream/ami_stream.h
 (number of items in each stream)
 more debug messages now turned on in that r41548 (6.5svn) ...
 hmmm I get "Free Memory=-1" in stats.out on 32bit linux too.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:12>
