[GRASS-dev] netbook and entering GRASS (wxpython gui + grass7svn)
Hamish
hamish_b at yahoo.com
Sat May 1 00:25:52 EDT 2010
see
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/descriptions/grass_description.html#L32
and
https://trac.osgeo.org/grass/ticket/509
--- On Fri, 4/30/10, Yann Chemin <yann.chemin at gmail.com> wrote:
> From: Yann Chemin <yann.chemin at gmail.com>
> Subject: [GRASS-dev] netbook and entering GRASS (wxpython gui + grass7svn)
> To: "GRASS developers list" <grass-dev at lists.osgeo.org>
> Date: Friday, April 30, 2010, 9:07 PM
> Hello list,
> when using GRASS (i.e. 7 svn of today) that is the wxPython
> GUI,
> the initial dialog box to choose location/mapset/etc is
> higher than
> the screen resolution.
> Thus it is difficult to access the "ENTER GRASS" button.
> The netbook I used is:
> eeePC 1000H with Debian Linux, default resolution is
> 1024x600, the 600
> height is the limiting factor here, since the button to
> enter in GRASS
> is half way more than 600 and the remaining part of the
> button inside
> 600 is appearing under the KDE panel (have to enable
> auto-hide
> function to see that half-button).
> That does not happen with tcl/tk gui that is v6.4.rcx in
> actual Debian
> Sid. The Tcl/Tk GUI maximizes to the screen height.
> Thank you,
> Yann
> Yann Chemin
> Senior Spatial Hydrologist
> www.csu.edu.au/research/icwater
> M +61-4-3740 7019
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
