[GRASS-dev] GRASS posters in svn add-on
Hamish
hamish_b at yahoo.com
Mon May 10 06:00:49 EDT 2010
Marjus:
> > which I have tried to copy over with "svn copy" which
> > bailed out with an error message. Also "svn move" is unsupported.
I used to have the same problem moving from grass-addons to the main
tree on my laptop. Solution was to make sure both had the identical source
URL. in my case the initial SVN checkout for grass-addons was done read-only
http:// instead of https://, so URLs were different. Enough of an "ah-ha"
moment that IIRC I documented the fix on the trac wiki "how to SVN" page.
regards,
Hamish
