[GRASS-dev] Re: [GRASS GIS] #1059: wxGUI: No menu option for
r.mapcalc
trac at osgeo.org
Wed May 12 03:04:55 EDT 2010
#1059: wxGUI: No menu option for r.mapcalc
Reporter: vesnikos | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: r.mapcalc wxGUI
Platform: Linux | Cpu: x86-32
Changes (by mmetz):
* status: reopened => closed
* resolution: => fixed
Comment:
Replying to [comment:20 martinl]:
> Replying to [comment:18 mmetz]:
> > So is there really a need for two GUI interfaces for r.mapcalc? I'm
sure it is possible to link r.mapcalc to the Map calculator GUI in the GUI
command search.
> No, r.mapcalc would searchable even not included in the menu. The owner
of this ticket requested to add r.mapcalc to the menu. So I did it.
See comment:6 and comment:7
The owner of the ticket wondered why the Map Culculator did not show up
when searching for r.mapcalc in the wxGUI command search option.
When I search for r.colors, I get 4 hits, so it is obviously possible in
the wxGUI command search to link a given command to more than one GUI
dialog and to link it to a custom dialog that is not generated
automatically by parsing [command] --interface-description. The
interactive map calculator is a GUI front end for r.mapcalc, so it would
be nice if that shows up when searching for r.mapcalc in the wxGUI command
search option.
> > From this point of view, even less reason to modify a core module like
r.mapcalc just for a quick wxGUI fix. OTOH, it's the only GUI in trunk,
and default for 6.4+ IIRC...
> Sorry, as a main contributor to the wxGUI I have little time for
testing. Moreover trunk is used for development. Broken r.mapcalc has been
fixed very soon thanks to Glynn. So where is the problem?
IMHO, as a main contributor to the wxGUI, you should spend most of the
time testing because it is still quite experimental to quote you.
My problem is that I don't like quick and dirty fixes and that I think
it's a good idea if main contributors test changes first before committing
so as not to break things.
Closing ticket because something shows up now when searching for the
command in question in the wxGUI command search and because this
discussion is no longer really related to the ticket, it's just my
personal nagging about (more) testing and being more careful when trying
to fix something.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1059#comment:21>
