[GRASS-dev] Re: wxGUI problems in 65 and 7
Markus Metz
markus.metz.giswork at googlemail.com
Thu May 13 09:25:34 EDT 2010
Markus Metz wrote:
> The windows position is no longer properly restored when opening
> wxGUI. Maybe that has something to do with my dual screen setup, so I
> tried all combinations of display on one monitor, layer manager on the
> other monitor, display and layer manager on first monitor, display and
> layer manager on second monitor, always save in preferences, restart
> grass and gui. The windows are never there where they are supposed to
> be. Weird is that if both are supposed to be on the same monitor, one
> is placed on one monitor, the other on the other monitor. The position
> of the layer manager is fairly arbitrary. Vice versa, if both are
> supposed to be on different monitors, they end up on the same monitor.
> Again, the position of the layer manager is not just shifted to the
> other monitor, it's fairly arbitrary.
> works fine in grass64, and worked fine before in grass65 and grass7
> (some weeks ago, can't remember the revision)
Hopefully fixed in r42248, problem was that any saved window position
was overruled and windows were always centered, ignoring saved
settings. My change may need review.
