[GRASS-dev] diglib test.c fails on 64bit win
Fri May 14 14:31:19 EDT 2010
Markus Metz wrote:
> To avoid confusion, on MINGW32 it would be better to not use
> _FILE_OFFSET_BITS=64 and don't set USE_LARGEFILES and HAVE_LARGEFILES
> even if LFS is requested? Unset/undefine somewhere in configure.in or
> a bit later in config.h.in USE_LARGEFILES and HAVE_LARGEFILES for
> MINGW32?
How about:
 if test $ac_cv_largefiles = yes; then
	USE_LARGEFILES=1
+	if test "$MINGW32" = yes ; then
+		AC_MSG_ERROR([*** --enable-largefile doesn't work on Windows])
+	fi
 fi
