[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler
neteler at osgeo.org
Fri May 14 15:09:19 EDT 2010
On Fri, May 14, 2010 at 4:12 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2010/5/14 Markus Neteler <neteler at osgeo.org>:
>> On Sun, Apr 18, 2010 at 10:44 AM, Markus Neteler <neteler at osgeo.org> wrote:
>>> I have tried to generate a new vector map with the new digitizer, but it fails:
>> This is still the case.
>> GRASS 6.4: A Python problem appears when generating a new vector map in
>> the digitizer (Start digitizer, new map, enter name, OK):
>> Unable to initialize display driver of vector digitizer. See 'Command
>> output' for details.
>> Details: 'NoneType' object has no attribute 'OpenMap' ()
>> GRASS 6.5: A different Python problem appears when generating a new vector map
>> in the digitizer (Start digitizer, new map, enter name, OK):
>> Reason: message=_("Unable to initialize display driver of vector "
>> Traceback (most recent call last):
>> File "/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/etc/wxpython/gui_modules/toolbars.py",
>> line 1123, in StartEditing
>> DigitError: <unprintable DigitError object>
> both issues are related to the same thing - bloody swig you are using
> for compiling vdigit extension compared to the swig version used for
> wxpython packaging. On my system everything works with swig 1.3.36.
I am not sure about this. It worked till recently without problems and I am
not aware of any changes in my swig or wxpython installation.
> Not sure when it will be fixed (me - not first item in my TODO list /
> nobody else probably interested to fix it). Anyway there is chance for
> 6.4.1.
Mhh, shipping 6.4 with broken digitizer.. am I the only one having this problem?
If yes then who cares :)
Markus
