[GRASS-dev] 6.4.0 blocker bugs
Martin Landa landa.martin at gmail.com
Fri May 14 15:30:22 EDT 2010
Hi Markus,
2010/5/14 Markus Neteler <neteler at osgeo.org>:
> both issues are related to the same thing - bloody swig you are using
>> for compiling vdigit extension compared to the swig version used for
>> wxpython packaging. On my system everything works with swig 1.3.36.
> I am not sure about this. It worked till recently without problems and I am
> not aware of any changes in my swig or wxpython installation.
when I use swig 1.3.40 -- the same errors, with swig 1.3.36 everything works.
>> Not sure when it will be fixed (me - not first item in my TODO list /
>> nobody else probably interested to fix it). Anyway there is chance for
>> 6.4.1.
> Mhh, shipping 6.4 with broken digitizer.. am I the only one having this problem?
> If yes then who cares :)
No you are not definitely alone, anyway wxGUI is not default GUI for
6.4.0, moreover there is still v.digit. I would like to have enough
time to fix all major issues related to wxGUI digitizer...
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
