[GRASS-dev] 6.4.0 blocker bugs
Maciej Sieczka msieczka at sieczka.org
Sat May 15 08:53:48 EDT 2010
W dniu 15.05.2010 12:40, Maciej Sieczka pisze:
> @Markus, Paul:
> How do you actually do such updates like [3]?
> [3]http://trac.osgeo.org/grass/changeset?old_path=grass%2Ftrunk%2Flib%2Fproj&old=41451&new_path=grass%2Ftrunk%2Flib%2Fproj&new=41452
OK now, so this was actually a revert of a massive update which broke
things.
Anyway, my point is that gcs.csv as it is now in all GRASS SVN branches
lacks towgs84 definition for Pulkovo 1942(58) datum, which results in
locations created from EPSG codes [4] lacking it too. The towgs84 should
be as in [5].
@Markus, Paul
Do I simply modify gcs.csv alone or should this be a somewhat bigger change?
Maciek
[4]3120 2172 2173 2174 2175 3333 3334 3335 3329 3330 3331 3332 3328 4179
[5]33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
Maciej Sieczka
http://www.sieczka.org
