[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler
neteler at osgeo.org
Sat May 15 09:18:41 EDT 2010
On Sat, May 15, 2010 at 2:53 PM, Maciej Sieczka <msieczka at sieczka.org> wrote:
> W dniu 15.05.2010 12:40, Maciej Sieczka pisze:
>> @Markus, Paul:
>> How do you actually do such updates like [3]?
>> [3]http://trac.osgeo.org/grass/changeset?old_path=grass%2Ftrunk%2Flib%2Fproj&old=41451&new_path=grass%2Ftrunk%2Flib%2Fproj&new=41452
> OK now, so this was actually a revert of a massive update which broke
> things.
Right - personally, I find it to be a major problem that we are out of
synch with GDAL now.
> Anyway, my point is that gcs.csv as it is now in all GRASS SVN branches
> lacks towgs84 definition for Pulkovo 1942(58) datum, which results in
> locations created from EPSG codes [4] lacking it too. The towgs84 should
> be as in [5].
> @Markus, Paul
> Do I simply modify gcs.csv alone or should this be a somewhat bigger change?
I have no idea, sorry. If you manage to generate a working patch it
will be hopefully
possible to include it in GRASS.
Markus
> Maciek
> [4]3120 2172 2173 2174 2175 3333 3334 3335 3329 3330 3331 3332 3328 4179
> [5]33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
> Maciej Sieczka
> http://www.sieczka.org
