[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
trac at osgeo.org
Sat May 15 16:41:22 EDT 2010
Reporter: sallar | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:14 glynn]:
> I'm not sure why the backtrace stopped (maybe the caller was built with
-fomit-frame-pointer?), but it looks like heap corruption. In which case,
the stack trace doesn't really help, as the error is in whatever caused
the heap corruption, not whatever happens to get bitten by it.
> valgrind might be able to help here.
Can you post here valgrind output ?
http://grass.osgeo.org/wiki/GRASS_Debugging#Using_Valgrind
Ticket URL: <http://trac.osgeo.org/grass/ticket/1032#comment:15>
