[GRASS-dev] makefile for Mac still not compiling wxpython GUI
section automatically
Michael Barton
Michael.Barton at asu.edu
Mon May 17 16:49:19 EDT 2010
I installed ctypesgen and this fixed the ../lib/python error. In fact, if I compile ../gui/wxpython, all compiles fine. BUT I hit the following error when I try to do a make install. A really weird error. I AM in the top level directory. I put ctypesgen inside my GRASS source, but otherwise haven't done anything to change this setup.
Michael
cmb-mbp:grass70_dev cmbarton$ sudo make install
Password:
include/Make/Docs.make:11: warning: overriding commands for target `htmldocs-single'
include/Make/Doxygen.make:12: warning: ignoring old commands for target `htmldocs-single'
include/Make/Docs.make:39: warning: overriding commands for target `htmldocs'
include/Make/Doxygen.make:18: warning: ignoring old commands for target `htmldocs'
include/Make/Docs.make:51: warning: overriding commands for target `pdfdocs'
include/Make/Doxygen.make:38: warning: ignoring old commands for target `pdfdocs'
include/Make/Docs.make:58: warning: overriding commands for target `cleandocs'
include/Make/Doxygen.make:50: warning: ignoring old commands for target `cleandocs'
echo /Users/cmbarton/grass_dev/grass70_dev/bin.i386-apple-darwin10.3.1/grass70
make -C macosx install-macosx
echo /Users/cmbarton/grass_dev/grass70_dev/dist.i386-apple-darwin10.3.1/GRASS-7.0.app
ERROR: GRASS.app has not been compiled. Try "make" in the top level source dir first.
Installation aborted, exiting Make.
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On May 17, 2010, at 12:04 PM, Markus Metz wrote:
> William Kyngesburye wrote:
>> The Mac makefile doesn't do any of the GRASS compilation, only the Mac startup compilation. gui/wxpython is always compiled, regardless of the system.
>> Maybe wxpython now needs something from a folder that is compiled after it (visualization, locale, man, swig), so it's quietly skipped?
> It's lib/python that needs to be fixed, see
> http://lists.osgeo.org/pipermail/grass-dev/2010-May/050502.html
> Glynn is looking for alternatives to SWIG and currently trying ctypesgen.
> Citing from
> http://lists.osgeo.org/pipermail/grass-dev/2010-May/050496.html
> ctypesgen can be obtained via SVN:
> svn checkout http://ctypesgen.googlecode.com/svn/trunk/ ctypesgen-read-only
> or you can get a tarball from:
> http://mirrors.kernel.org/gentoo/distfiles/ctypesgen-0_p72.tar.bz2
> To build:
> python setup.py build install
> Although it's probably not as widespread as SWIG, it has the advantage
> that both ctypesgen itself and the wrappers which it generates are
> pure Python code, with no binary components.
> I'm also going to look at ctypeslib:
> http://pypi.python.org/pypi/ctypeslib/
> I went with ctypesgen first as there's a supported Gentoo package for
> it.
> Get ctypesgen, install it or put ctypesgen.py somewhere in your path,
> that should do the trick.
>> On May 17, 2010, at 12:58 PM, Michael Barton wrote:
>>> The makefile for the Mac needs to be changed so that it compiles the wxpython folder automatically. Currently you must cd to the folder in order to compile this. It didn't used to be this way.
>>> On 6.5 and 7.
>>> Michael
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> All generalizations are dangerous, even this one.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
