[GRASS-dev] Re: i.pr in GRASS6.4
António Rocha
antonio.rocha at deimos.com.pt
Tue May 18 10:39:22 EDT 2010
I'm sorry but I need to make a correction regarding this. This was done
for GRASS6 so Makefiles will be similar to the ones that GRASS6.4 has.
Ok I have downloaded i.pr into my LINUX (Ubuntu machine) and I've used
this command to compile:
sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
Attached to this email is the installation LOG. I had a few errors,
regarding Description.html but how is the rest? OK?
(will it work on GRASS6.4?)
Thank you
best regards,
Antonio Rocha
António Rocha wrote:
> Greetings all
> I've seen a few emails, at GRASS users mailing list regarding i.pr
> module. This module, developed for GRASS5 by Stefano Merler , is a
> multi-tool to perform Classification for a wide set of methods. This
> is a good asset for GRASS having this tool "fully working" on GRASS 6.4.
> has anyone tried to "redone" this tool to GRASS6.4.?
> Thank you so much for your help
> Best regards,
> Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5124 (20100518) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
