[GRASS-dev] Re: i.pr in GRASS6.4
António Rocha
antonio.rocha at deimos.com.pt
Tue May 18 10:41:34 EDT 2010
Ups forgot the attachment.. Sorry
All executables were created...
António Rocha wrote:
> I'm sorry but I need to make a correction regarding this. This was
> done for GRASS6 so Makefiles will be similar to the ones that GRASS6.4
> has.
> Ok I have downloaded i.pr into my LINUX (Ubuntu machine) and I've
> used this command to compile:
> sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
> Attached to this email is the installation LOG. I had a few errors,
> regarding Description.html but how is the rest? OK?
> (will it work on GRASS6.4?)
> Thank you
> best regards,
> Antonio Rocha
>> Greetings all
>> I've seen a few emails, at GRASS users mailing list regarding i.pr
>> module. This module, developed for GRASS5 by Stefano Merler , is a
>> multi-tool to perform Classification for a wide set of methods. This
>> is a good asset for GRASS having this tool "fully working" on GRASS 6.4.
>> has anyone tried to "redone" this tool to GRASS6.4.?
>> Thank you so much for your help
>> Best regards,
>> Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5124 (20100518) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
make: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr'
PRLIB
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/PRLIB'
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/blob.o -c blob.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/bootstrap.o -c bootstrap.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/dist.o -c dist.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/eigen.o -c eigen.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/entropy.o -c entropy.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/features.o -c features.c
features.c: In function âcompute_featuresâ:
features.c:149: warning: format not a string literal and no format arguments
features.c:178: warning: format not a string literal and no format arguments
features.c:182: warning: format not a string literal and no format arguments
features.c:189: warning: format not a string literal and no format arguments
features.c:214: warning: format not a string literal and no format arguments
features.c: In function âwrite_featuresâ:
features.c:325: warning: format not a string literal and no format arguments
features.c: In function âstandardize_featuresâ:
features.c:523: warning: format not a string literal and no format arguments
features.c:542: warning: format not a string literal and no format arguments
features.c: In function âread_featuresâ:
features.c:705: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/features_selection.o -c features_selection.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/getline.o -c getline.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/gm.o -c gm.c
gm.c: In function âwrite_gmâ:
gm.c:149: warning: format not a string literal and no format arguments
gm.c: In function âtest_gmâ:
gm.c:233: warning: format not a string literal and no format arguments
gm.c: In function âpredict_gm_multiclassâ:
gm.c:361: warning: format not a string literal and no format arguments
gm.c: In function âpredict_gm_2classâ:
gm.c:420: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/integration.o -c integration.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/lu.o -c lu.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/matrix.o -c matrix.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/min_quadratic.o -c min_quadratic.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/nn.o -c nn.c
nn.c: In function âwrite_nnâ:
nn.c:60: warning: format not a string literal and no format arguments
nn.c: In function âtest_nnâ:
nn.c:247: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/open.o -c open.c
open.c: In function âopen_new_CELLâ:
open.c:24: warning: format not a string literal and no format arguments
open.c:32: warning: format not a string literal and no format arguments
open.c: In function âopen_new_DCELLâ:
open.c:51: warning: format not a string literal and no format arguments
open.c:59: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/pca.o -c pca.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/percent.o -c percent.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/random.o -c random.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/read_models.o -c read_models.c
read_models.c: In function âread_modelâ:
read_models.c:43: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/soft_margin_boosting.o -c soft_margin_boosting.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/sort.o -c sort.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/stats.o -c stats.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/svm.o -c svm.c
svm.c: In function âwrite_svmâ:
svm.c:938: warning: format not a string literal and no format arguments
svm.c: In function âtest_svmâ:
svm.c:1045: warning: format not a string literal and no format arguments
svm.c: In function âwrite_bagging_boosting_svmâ:
svm.c:1265: warning: format not a string literal and no format arguments
svm.c: In function âtest_bsvmâ:
svm.c:1579: warning: format not a string literal and no format arguments
svm.c: In function âtest_bsvm_progressiveâ:
svm.c:1658: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/test.o -c test.c
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/training.o -c training.c
training.c: In function âread_trainingâ:
training.c:57: warning: format not a string literal and no format arguments
training.c:87: warning: format not a string literal and no format arguments
training.c:99: warning: format not a string literal and no format arguments
training.c:165: warning: format not a string literal and no format arguments
training.c:170: warning: format not a string literal and no format arguments
training.c:175: warning: format not a string literal and no format arguments
training.c:183: warning: format not a string literal and no format arguments
training.c:204: warning: format not a string literal and no format arguments
training.c:221: warning: format not a string literal and no format arguments
training.c:228: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/tree.o -c tree.c
tree.c: In function âwrite_treeâ:
tree.c:360: warning: format not a string literal and no format arguments
tree.c: In function âwrite_bagging_boosting_treeâ:
tree.c:1262: warning: format not a string literal and no format arguments
tree.c: In function âtest_treeâ:
tree.c:1407: warning: format not a string literal and no format arguments
tree.c: In function âtest_btreeâ:
tree.c:1552: warning: format not a string literal and no format arguments
tree.c: In function âtest_btree_progressiveâ:
tree.c:1640: warning: format not a string literal and no format arguments
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I../include/ -DPACKAGE=\""grasslibs"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/write_matrix.o -c write_matrix.c
write_matrix.c: In function âwrite_matrixâ:
write_matrix.c:16: warning: format not a string literal and no format arguments
gcc -shared -o /usr/local/grass-6.4.0svn/lib/libgrass_pr.6.4.0svn.so -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib OBJ.i686-pc-linux-gnu/blob.o OBJ.i686-pc-linux-gnu/bootstrap.o OBJ.i686-pc-linux-gnu/dist.o OBJ.i686-pc-linux-gnu/eigen.o OBJ.i686-pc-linux-gnu/entropy.o OBJ.i686-pc-linux-gnu/features.o OBJ.i686-pc-linux-gnu/features_selection.o OBJ.i686-pc-linux-gnu/getline.o OBJ.i686-pc-linux-gnu/gm.o OBJ.i686-pc-linux-gnu/integration.o OBJ.i686-pc-linux-gnu/lu.o OBJ.i686-pc-linux-gnu/matrix.o OBJ.i686-pc-linux-gnu/min_quadratic.o OBJ.i686-pc-linux-gnu/nn.o OBJ.i686-pc-linux-gnu/open.o OBJ.i686-pc-linux-gnu/pca.o OBJ.i686-pc-linux-gnu/percent.o OBJ.i686-pc-linux-gnu/random.o OBJ.i686-pc-linux-gnu/read_models.o OBJ.i686-pc-linux-gnu/soft_margin_boosting.o OBJ.i686-pc-linux-gnu/sort.o OBJ.i686-pc-linux-gnu/stats.o OBJ.i686-pc-linux-gnu/svm.o OBJ.i686-pc-linux-gnu/test.o OBJ.i686-pc-linux-gnu/training.o OBJ.i686-pc-linux-gnu/tree.o OBJ.i686-pc-linux-gnu/write_matrix.o -lgrass_gmath -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lm && \
(cd /usr/local/grass-6.4.0svn/lib; ln -f -s libgrass_pr.6.4.0svn.so /usr/local/grass-6.4.0svn/lib/libgrass_pr.so)
make[1]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/PRLIB'
i.pr_blob
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
gcc -I/usr/local/grass-6.4.0svn/include -g -O2 -I../include/ -DPACKAGE=\""grassmods"\" -I/usr/local/grass-6.4.0svn/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function âmainâ:
main.c:104: warning: format not a string literal and no format arguments
main.c:109: warning: format not a string literal and no format arguments
gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib -o /usr/local/grass-6.4.0svn/bin/i.pr.blob OBJ.i686-pc-linux-gnu/main.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lz -lgrass_display -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lm -lz
make htmlcmd
make[2]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
make /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html HTMLSRC=/usr/local/grass-6.4.0svn/bin/i.pr.blob
make[3]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
if [ "/usr/local/grass-6.4.0svn/bin/i.pr.blob" != "" ] ; then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64 GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH" LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:" LC_ALL=C /usr/local/grass-6.4.0svn/bin/i.pr.blob --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.blob.tmp.html ; true ; fi
/usr/local/grass-6.4.0svn/tools/mkhtml.sh i.pr.blob ; mkdir -p /usr/local/grass-6.4.0svn/docs/html ; /usr/bin/install -c -m 644 i.pr.blob.tmp.html /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/local/grass-6.4.0svn/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
make[2]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
make mancmd
make /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 MANSRC=/usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html
mkdir -p /usr/local/grass-6.4.0svn/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
make[2]: *** [mancmd] Error 2
make[1]: *** [cmd] Error 2
make[1]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_blob'
i.pr_classify
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
main.c:111: warning: format not a string literal and no format arguments
main.c:115: warning: format not a string literal and no format arguments
main.c:127: warning: format not a string literal and no format arguments
main.c:132: warning: format not a string literal and no format arguments
main.c:196: warning: format not a string literal and no format arguments
main.c:201: warning: format not a string literal and no format arguments
main.c:209: warning: format not a string literal and no format arguments
main.c:214: warning: format not a string literal and no format arguments
main.c:234: warning: format not a string literal and no format arguments
main.c:394: warning: format not a string literal and no format arguments
gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib -o /usr/local/grass-6.4.0svn/bin/i.pr.classify OBJ.i686-pc-linux-gnu/main.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lz -lgrass_display -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lm -lz
make htmlcmd
make[2]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
make /usr/local/grass-6.4.0svn/docs/html/i.pr.classify.html HTMLSRC=/usr/local/grass-6.4.0svn/bin/i.pr.classify
make[3]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
if [ "/usr/local/grass-6.4.0svn/bin/i.pr.classify" != "" ] ; then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64 GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH" LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:" LC_ALL=C /usr/local/grass-6.4.0svn/bin/i.pr.classify --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.classify.tmp.html ; true ; fi
/usr/local/grass-6.4.0svn/tools/mkhtml.sh i.pr.classify ; mkdir -p /usr/local/grass-6.4.0svn/docs/html ; /usr/bin/install -c -m 644 i.pr.classify.tmp.html /usr/local/grass-6.4.0svn/docs/html/i.pr.classify.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/local/grass-6.4.0svn/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
make[2]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
make mancmd
make /usr/local/grass-6.4.0svn/man/man1/i.pr.classify.1 MANSRC=/usr/local/grass-6.4.0svn/docs/html/i.pr.classify.html
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man /usr/local/grass-6.4.0svn/docs/html/i.pr.classify.html /usr/local/grass-6.4.0svn/man/man1/i.pr.classify.1 1
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.classify.1] Error 2
make[1]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_classify'
i.pr_features
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
main.c:137: warning: format not a string literal and no format arguments
main.c:151: warning: format not a string literal and no format arguments
main.c:182: warning: format not a string literal and no format arguments
main.c:205: warning: format not a string literal and no format arguments
main.c:228: warning: format not a string literal and no format arguments
main.c:251: warning: format not a string literal and no format arguments
gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib -o /usr/local/grass-6.4.0svn/bin/i.pr.features OBJ.i686-pc-linux-gnu/main.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lz -lgrass_display -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lm -lz
make htmlcmd
make[2]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
make /usr/local/grass-6.4.0svn/docs/html/i.pr.features.html HTMLSRC=/usr/local/grass-6.4.0svn/bin/i.pr.features
make[3]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
if [ "/usr/local/grass-6.4.0svn/bin/i.pr.features" != "" ] ; then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64 GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH" LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:" LC_ALL=C /usr/local/grass-6.4.0svn/bin/i.pr.features --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.features.tmp.html ; true ; fi
/usr/local/grass-6.4.0svn/tools/mkhtml.sh i.pr.features ; mkdir -p /usr/local/grass-6.4.0svn/docs/html ; /usr/bin/install -c -m 644 i.pr.features.tmp.html /usr/local/grass-6.4.0svn/docs/html/i.pr.features.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /usr/local/grass-6.4.0svn/docs/html ; fi done 2> /dev/null ; true
make[3]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
make[2]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
make mancmd
make /usr/local/grass-6.4.0svn/man/man1/i.pr.features.1 MANSRC=/usr/local/grass-6.4.0svn/docs/html/i.pr.features.html
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man /usr/local/grass-6.4.0svn/docs/html/i.pr.features.html /usr/local/grass-6.4.0svn/man/man1/i.pr.features.1 1
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.features.1] Error 2
make[1]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features'
i.pr_features_additional
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features_additional'
main.c:88: warning: format not a string literal and no format arguments
main.c: In function âgenerate_featuresâ:
main.c:243: warning: format not a string literal and no format arguments
main.c:247: warning: format not a string literal and no format arguments
main.c:255: warning: format not a string literal and no format arguments
main.c:279: warning: format not a string literal and no format arguments
gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib -o /usr/local/grass-6.4.0svn/bin/i.pr.features_additional OBJ.i686-pc-linux-gnu/main.o -lgrass_sites -lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -lgrass_rtree -lgrass_pr -lgrass_I -lgrass_gis -lgrass_datetime -lz -lgrass_display -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_raster -lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lpng -lz -lm -lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_driver -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lm -lz
make htmlcmd
make[2]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features_additional'
make /usr/local/grass-6.4.0svn/docs/html/i.pr.features_additional.html HTMLSRC=/usr/local/grass-6.4.0svn/bin/i.pr.features_additional
make[3]: Entering directory `/home/anrr/Desktop/GRASS_dvp/i.pr/i.pr_features_additional'
if [ "/usr/local/grass-6.4.0svn/bin/i.pr.features_additional" != "" ] ; then GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64 GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH" LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:" LC_ALL=C /usr/local/grass-6.4.0svn/bin/i.pr.features_additional --html-description < /dev/null | grep -v '</body>\|</html>' > i.pr.features_additional.tmp.html ; true ; fi
http://www.eset.com
