[GRASS-dev] Re: i.pr in GRASS6.4
Markus Neteler markus.neteler at iasma.it
Wed May 19 06:23:49 EDT 2010
The MAN manual building script is either not existing on
your machine or perl fails:
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
/usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
/usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html
/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
That's harmless for the usage.
For the rest, there are warnings which should ideally be fixed but
warnings are not necessarily errors.
Perhaps you would just try the tools?
Markus
On 05/18/2010 04:41 PM, António Rocha wrote:
> Ups forgot the attachment.. Sorry
> All executables were created...
>> I'm sorry but I need to make a correction regarding this. This was
>> done for GRASS6 so Makefiles will be similar to the ones that
>> GRASS6.4 has.
>> Ok I have downloaded i.pr into my LINUX (Ubuntu machine)  and I've
>> used this command to compile:
>> sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
>> Attached to this email is the installation LOG. I had a few errors,
>> regarding Description.html but how is the rest? OK?
>> (will it work on GRASS6.4?)
>> Thank you
>> best regards,
>> Antonio Rocha
>>> Greetings all
>>> I've seen a few emails, at GRASS users mailing list regarding i.pr
>>> module. This module, developed for GRASS5 by Stefano Merler , is a
>>> multi-tool to perform Classification for a wide set of methods. This
>>> is a good asset for GRASS having this tool "fully working" on GRASS
>>> 6.4.
>>> has anyone tried to "redone" this tool to GRASS6.4.?
>>> Thank you so much for your help
>>> Best regards,
>>> Antonio Rocha
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 5124 (20100518) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100519/c05d600d/attachment.html
