[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example
[SEC=UNCLASSIFIED]
Glynn Clements
glynn at gclements.plus.com
Wed May 19 11:49:21 EDT 2010
Martin Landa wrote:
> > This particular issue should be fixed by r42311. I don't know if this
> > is related to the problem, but it's something to eliminate.
> right, this issue is eliminated, anyway the reported problem still persists.
The only other thing which I can suggest is to add print statements to
the functions in $GISBASE/etc/python/grass/lib/ctypesheader.py,
specifically String.__init__ and String.from_param.
